The message states maintenance required call for service
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
SOURCE: Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
SOURCE: u2-40
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
SOURCE: Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
SOURCE: I have a Sharp MX-C310
http://printcopy.info/?l=en&mod=docs&brand=Sharp&prefix=MX-C&gID=19364
Hi above is your service and repair manual it shows you what to do in there open or download and follow the instructions.
Below is you user manual, here too is what to do...
www.sharp.co.uk/.../MXC310-C311-C380-C381-C400_OM_Software_GB.pdf
Maintenance-Safety-Guide below
www.sharp.co.uk/.../MXC310-C311-C380-C381-C400_OM_Maintenance-Safety-Guide_GB.pdf
copy/paste above to address bar, if not live.
