Cassette Error Message
The cassettes have little motors on them that lift the paper up to the rollers when it's closed. Make sure there isnt a bind on the plate that lifts the paper up. If there isn't you might need a lift motor replaced. This is a pretty common issue.
www.equipmybiz.com Skelton Business Equipment Houston Copiers
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in
the paper. You have to do 2 simple things, from which one will solve
the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect
paper format. Solution is very simple. Open MS word or something
similar, file->print.. and before you print open Properties menu.
There for the Output Size will be selected "Match Page Size". you don't
want that (i don't know why it doesn't work), but the solution is
manually select A4, or whatever your page size is.
SOURCE: Kyocera FS 4000 cassette error
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
SOURCE: Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
SOURCE: kyocera fs-2020d doesnt do multiple copies of documents
This message often shows up when the memory is full from one document (normally a large file) to fix it you have to add external memory
