Won't accept my log-in. I have always used the same one.
I can't log-on to my computer. It won't let me use the same password which I have been using forever. I never changed it but it keeps giving me the message that it is "unable to accept user profile".
I met the same trouble, i just reset acer password by the following steps, Step1.Download Smartkey Windows Password Recoveryfrom recoverlostpassword.com anddecompress it on that PC. There is a .ISO file. Burn the .ISO file to CD or USBFlash Driver.Step2.Get out the newly created CDor USB Flash Driver and insert it to the locked computer.Step3. Re-boot the locked computerand then follow the process of instructions. Just after a few steps, the oldpassword will be removed.It can recover all Windows version.
Your situation might have happened during logging in or while using Find Friends.
If it had happened during logging in, then you need to provide the e-mail ID and the Password you provided during Facebook signup.My guess is you would have entered password of your mail account in Facebook.
If it is during 'Find Friends', then you might have entered wrong password for your mail id.
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.
Click on one of these links todownload HIREN'S BOOTCD :-
http://www.hirensbootcd.net/http://67.20.82.163/
Okay, first the password problem. Passwords are almost always case-sensitive now, so make sure that your caps lock is in the same state it was in when you first set the password. I have seen it happen that someone will set the password while their caps lock is on, then when they try to log in later with the caps lock off, they get a wrong password error. More often, though, is the opposite. You set the password with the caps lock off, and are trying to log in with it on.
The second problem is a little more complicated. First of all, the file InfraRecorderPortable_0.52.paf.exe is an installation file, which means it won't do the CD burning as it is. If you want to use the portable version of that software (for example, you have a friend that doesn't have that program on their computer, and they don't want it installed, but you still want to use it)you'll have to run the program and when it asks where you want to install it, select your USB stick. It should be able to run from there without any other supporting programs.
Go to the forgot password link and enter your email address which you used when signed up.after that check your email they will send you new password.try login using it.if its not work than make new account with new email id ,when you filled up sign-up form than save your page with details you entered so you can remember it for long time.now log-in to your account using new email id and password.
when you log in to msn and you have entered your user name why dont you highlight forgot my password and then reset it with a new one it is better you reset it caused the password is no longer a password because every one else knows it now so i would suggest you to change your password.
