Televison & Video Logo
R
Robert Harrison Posted on Aug 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my Sharp VCR pops out all my tapes without playing?
Sharp VCR model# VC-A5640
  • Robert Harrison
    Robert Harrison Aug 05, 2014
    I tied the tension of the tape. This was not the problem as none of my
  • Robert Harrison
    Tapes work. They all eject and wont play.
A Miller
Level 3:
  • Sharp Master 8,404 Answers
  • Posted on Aug 05, 2014
A Miller
Sharp Master
Level 3:
Answers
8404
Questions
Helped
2051006
Points
24677
Check the tape tension ... rewind and rere-rewind and try that.
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Feb 05, 2008
SOURCE: Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Anonymous
  • Posted on Feb 07, 2007
SOURCE: sharp vcr
I wondered if you were able to get a copy of the manual. Does anybody know how to reset the tamper proof button that needs a code. MY child seems to have set this with a code.. Any help would be much appreciated. Thanks
Anonymous
  • Posted on Mar 28, 2008
SOURCE: reording from tv to a sharp vc-a560
I am not sure how I fixed it but It works now. Thank You :)
Anonymous
  • Posted on Jan 08, 2009
SOURCE: sharp vc-A410U vcr
If the belt does not solve problem it could be the idler tyre is worn and/or clutch, this quite often happens when tape has been playing for a while and most of tape is on right hand side, causing greater drag on take up spool.
gigo95677
  • Posted on Feb 19, 2009
SOURCE: owners manual for vc-h952u vcr
I have a manual and can email it after I scan it.
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
My sharp VCR wont accept tapes, they pop out when I insert them, help?
This often caused by a faulty carriage assembly. Another cause is a mode switch failure. The mode switch tells the electronics what position the VCR mechanism is in. When it goes faulty it will cause the tape to eject sometimes. However any kind of mechanism damage can cause the mode switch to go into a wrong position.
Sharp VC-H973U suddenly unable to play/record tapes
With these things it's best to see what is going on to see if it can be fixed. So what I suggest you do is take the top cover off and using an old tape which you don't mind getting mangled insert it and watch where it gets tangled up. Without looking into it you can't determine what's faulty.
I have a Sharp VC-A410 and while watching a movie play will start flashing on the screen and it looks like the movie is skipping.
try a head cleaner tape, or professional head cleaning... aslo try another tape. Videotape is easily damaged as are the heads...
1helpful
7answers
I have trouble taping when i put the timer on it does't tape.
You are looking for a user manual? Is the Sharp VC-A554U VHS VCR the correct model or do you have another device?
Thank you.
2helpful
2answers
Sharp vc-A410U vcr
replace the capstan motor belt.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
