Coolpix s800c white digital camera
SOURCE: finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
SOURCE: Nikon Coolpix digital camera L18
The red light is probably the focusing beam. I'd guess that your flash is turned off somewhere in your settings. Go through the menu and if you find that it is not turned on there might be a hardware problem. Also, if the flash is set to automatic, it will not work when it thinks there is enough light to take a good pic.
SOURCE: Whenever I take a picture
I´ve got the same problem and think, that it`s the ccd unit.
Someone is offering the lens with ccd unit on ebay.
Best regards
Fite
[email protected]
SOURCE: Dear Expert, I have a Nikon coolpix S570 digital
Yes the possible solution is alright but there are errors within the camera. Sometimes the lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for spares.
