Canon Printer fix error 5b01
Hope theese links can help you :
Cara Reset Canon IP2770 Error 5B01 docx
you can use google translate here to copy and paste the foreign text :
Google Translate
SOURCE: 5boo error for Cannon iP
your wastepad is full try to visit http://pcmediks.blogspot.com/2010/09/canon-ip2770-resetter.html it works for me
SOURCE: i have a number 5200
unplug the power n usb cord
- keep the headprint inside the craddle
- try to move the headprint into full right-corner(headprint
cleaningside)by moving-left the craddle belt until u heard
some "snapp" sound
- plug the powercord again
- if u heard "cleaning progress" then u r printer going to respond
- try to print 'printer test page' or 'nozzle check'
- if it succeed, try to print some 5-10 pages continously
good luck...
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
SOURCE: service error 5100 on Canon
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
SOURCE: i have a canon printer
Here's How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
