Ipd air
Yup. Just delete it from accounts in settings, then add the google credentials.
See picture imthemobile guru
SOURCE: Can't delete emails from trash
Hello sir !
Empty Trash Can
In 1982, when Apple created the Apple Lisa user interface, they implemented what they called the Trash Can.
The trash can is essentially purgatory for files a user no longer
wants. Once sent to the trash, the user has the option of restoring the
file back to its original place, or annihilating it completely from the
computer’s hard drive. Unless there is a backup of a user’s system from
before the file was sent to the trash, there is essentially no way of
restoring that file once the trash has been emptied.
This metaphor was carried over to Windows 95
in the form of a Recycle Bin. Perched on the desktop of countless
millions of averages users was this bin which, when empty, looked
empty, and when it contained files, looked full.
There is safety in the Trash Can metaphor. I know that in order to
really delete a file from my system, either on Windows or on Mac OS X,
I really have to work at it. Yes, there are times when files are
accidentally deleted, but for the most part if I realize my mistake
before I empty my Trash, I know the file is safe.
SOURCE: I cannot get my roadrunner mail to work on my
Hi. Try this torubleshoothig steps. Delete the mail account and start over with the defaults ... Or start here => For the SMTP server, use host "smtp-server.nc.rr.com", change the default port from 587 to port 25 (in coming pop server should be 110 by default). If you have mail in your Outbox you will get a error message that you cannot connect, delete all mail in Outbox, now try sending yourself mail.
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
SOURCE: deleting old words with friends games on the ipad
Push and hold app until jiggliing with x.Tap x to delete from ipad.
SOURCE: how do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
1. Tap the Mail icon at the bottom of the home screen on iPad.
Step 2. Then tap to add type of email account that you want at add among: Microsoft Exchange, Mobile me, Gmail, Yahoo Mail, AOL or others. For example, if you want to add a Yahoo mail, just tap the Yahoo mail as follows:
Step 3. Then enter login details for selected email account type.
It will configure automatically and you should able to send - receive emails.
