How to set toner level in mita kyocera km2o30
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
SOURCE: Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
