Televison & Video Logo
A
Anonymous Posted on Aug 07, 2014
UNLOCK TV TOSHIBA
THE TV TURNS ON BUT REQUIRES 4 DIGIT CODE TO UNLOCK IT IS TOSHIBA REGZA 37WLT66A SERIAL NO 25009834 TV HOW DO I GET CODE
Bill Rochester
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Aug 07, 2014
Bill Rochester
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
6031
Points
25
Call Toshiba @ 1800_618_4444 with the same information you provided here, or use .http://www.toshiba.com/tai/americas/index.jsp
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Sep 13, 2009
SOURCE: I have a Toshiba Regza 42A3030D TV but no manual.
Paid for only:
http://www.user-manuals.com/advanced_search_result.php?keywords=42A3030D+manual&forward=plist
Or try eBay.
Anonymous
  • 47 Answers
  • Posted on Sep 19, 2009
SOURCE: My comcast remote requires a 5 digit remote code
Alot of times adding a couple of zero's before the actual code sometimes does the trick. Have you tried contacting Comcast???
There are times where the manufacturer will not list a code for an AFTER MARKET remote, which any remote control that is not made by the manufacturer is considered an AFTER MARKET control.
Chi Chu
  • 8457 Answers
  • Posted on Oct 12, 2009
SOURCE: how do you play games on a regza toshiba tv
What game system are being set to this tv?IF PS3 use a HDMI cable for connection to play.
Anonymous
  • Posted on Nov 10, 2009
SOURCE: When switching on my 32c3035d toshiba regza lcd tv
i had the same problem with the same television, apparently it is a faulty power supply board.if you can remove the power supply board and send it to digifix at buxton they will repair it for you.Beast to contact michael at digifix tho and describe your problems as it may be something else.
Sparky2012
Sergio Shamshoian
  • 102 Answers
  • Posted on Dec 05, 2009
SOURCE: need 4-digit code for Phillips 32' flat panel and
Here is the link to find owners manual of your remote.
http://www.p4c.philips.com/files/s/sru3004_27/sru3004_27_dfu_aen.pdf
4answers
2helpful
HOW TO GET UNLOCK CODE ?UNLOCK TV TOSHIBA
"If you cannot remember your PIN code
While the PIN code entering screen is displayed, press [RECALL] four times within five seconds. The PIN code will be cleared and you can enter a new PIN code."
Or you can trye this:
Step3Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
NEED CODE TO PROGAM TOSHIBA TV
Hi
You can trye this:
2helpful
Codes for regza tv 32AV554D
Hello
You asks universal remote codes for Toshiba, I assumes, and post this solution.
Four digit codes are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device
    responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code for toshiba regza tv
Hello
Three digit setup codes for Toshiba TV are:
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
OK.
1helpful
2answers
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Need rca univeral remote code for a toshiba tv
1. Manually turn on the component you want the remote
to control.
2. Press and hold the component key (TV, DVD•VCR, AUX, SAT•CBL) you wish to program. The LED INDICATOR turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the LED INDICATOR blinks four times, and the process is exited.
3. While holding down the component key, enter the four-digit code. While you are pressing the numbers, the LED INDICATOR turns off.
4. After the fourth number is entered, the LED INDICATOR turns on. At this time, release the component key. If the LED INDICATOR turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If the LED INDICATOR blinks four times when the component key is released, This means that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
RCA Toshiba 3 digit codes. 000,018,021,023,048,049,071,072,073,085,...
RCA Toshiba 4 digit codes.1000,1048,1072,1105, 1109, 1118,1160,1190,1241 Good Luck
4helpful
2answers
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
3answers
Toshiba CT-90275 3 digit code for Direct Tv R-16
Not really too sure about Direct TV. But give me some time, I have asked some other Experts here for their help. Hopefully one or two of them may have an answer..
Please do not rate this solution yet..
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
