SOURCE: SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
SOURCE: SIMPLETECH 160GB EXTERNAL HARD DRIVE
Is this compatible with vista?
Ensure all the plugs are right and try on a different pc to see if its the pcs or the exhdd's problem
SOURCE: i have a simpletech pininfarina 500 external
I have found a driver page of simpletech:
http://www.simpletech.com/support/support_downloads.php
I believe that driver for your model is not available in the above link.
The drive would not be recognized when it is not compatible with your notebook hard disk.
I suggest you to contact simpletech for getting the drivers as they will have the hard disk drivers.
SOURCE: computer does not recognize simpletech
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
SOURCE: how do I use my simpletech external hard drive. I
I have a 500GB and a 1TB. Both drives if they work at all, is because you have to apply the power after usb is connected. The 500MB still good but the 1TB took a big dump.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is your model number on the external?
