Be sure that you have the vents for the air flow in your freezer not covered up by boxes or bagged foods. It has to be able to circulate through the freezer towards the door and back to the vents if that is all clear the you may have an issue with the clicks on switch that tells it to defrost when it gets frozen up and can blow cold air through vents any more it also could be a bad element that works with the clicks o switch that tells element to come on and defrost. If that's not then you maybe low on refrigerant. .hope this helps
