SOURCE: Transferring Contacts to iPhone 3G
I would take it to the local ATT store and have them do it. It should be free, given that you have moved from ATT to ATT, just on a different phone. Ask more than one store if you get any trouble from them.
SOURCE: Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
SOURCE: Move contacts from Tungsten E2 to iPhone
If the Tungsten has a SIM card you can save the contacts to that, put that in the iPhone and go to Settings>Mail, Contacts, Calendars> Import SIM Contacts. If that isn't a option you may be able to export as VCards and import them into Address Book if you use a Mac. I'm not familiar with a way to do this on a PC. Anyone else have a solution?
SOURCE: iphone 3g text msg sending error. SOLVED only when..
Try resetting your iPhone this should solve your problem.
SOURCE: How do i recover deleted history on iphone 3g
Following steps can help you to recover deleted history on iPhone 3G
1.Connect your iPhone and Scan it-- After downloading the iOS Data Recovery, run it on the computer and connect your iPhone with the computer by a USB cable. Then click on the "Start Scan" button. The program will begin scanning your iPhone for deleted messages on it. Don't disconnect your iPhone during the whole time.
2.Preview and Recover Text Messages from your iPhone-- When the scan finishes, you can see all your found data listed in clear, organized categories. Choose Messages and Messages Attachments to preview the detailed content. And click what you want and click on Recover to save them on your PC.
Thanks
