After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.) While pressing [3] and [CLEAR] button, turn the power ON. When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START] button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2)) * When the FAX unit (GD-1150) is installed. Start up with the FAX Clearing Mode (1*) Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
First download this software: Ultimate Unlocker v1.01 by Cruiser Team(search google its free!)
Follow the example given below:
Successfully unlock K660i (A2)
17:25:25 Ultimate Unlocker v1.01 by Cruiser Team
17:25:26 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
17:25:26 Initializing...
! 17:25:26 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:25:26 2. Choose the phone model
! 17:25:26 3. Select the desired options
! 17:25:26 4. Please connect the phone either via USB while holding 2-5…
! 17:25:26 - or via a serial cable and double-click on it in the device list
17:25:34 Connecting via Generic EMP USB Flash Device (USB1)…
17:25:34 Device driver version: 1.1.0.12
17:25:34 Device driver date: 9-25-2006
17:25:35 Connecting to the baseband CPU...
17:25:35 Entering baseband CPU service mode...
17:25:35 Detected chipset: DB3150
17:25:35 Boot mode: ROM
17:25:36 Sending loader...
17:25:37 IMEI: xxxxxxxxxxxxxxx 17:25:37 OTP CID: 52
17:25:37 Product type: Retail
17:25:37 Effective color: Red
17:25:39 Sending loader...
17:25:40 Communicating with server…
17:25:44 Remainig credit (supreme): 1.00
17:25:49 Remainig credit (supreme): 1.00
17:25:49 Converting phone to blue…
17:25:49 Please reconnect the phone (disconnect, connect while holding 2-5)
17:26:01 Sending loader...
17:26:02 IMEI: xxxxxxxxxxxxxxx
17:26:02 OTP CID: 52
17:26:02 Product type: Retail
17:26:02 Effective color: Blue
17:26:04 Sending loader...
17:26:08 Code NCK for relock: 9753585490502778
17:26:08 Code NSCK for relock: 3889412532359257
17:26:08 Code SPCK for relock: 3171907565654182
17:26:08 Code CCK for relock: 6478061648618760
17:26:08 Code PCK for relock: 3949070691496765
17:26:08 Code ESLCK for relock: 9101944641118096
17:26:08 Code NCK for unlock: 9012406338647640
17:26:08 Code NSCK for unlock: 2040670855123632
17:26:08 Code SPCK for unlock: 0923191541634191
17:26:08 Code CCK for unlock: 4556970785063717
17:26:08 Code PCK for unlock: 1754665636774190
17:26:08 Code ESLCK for unlock: 2257853277910517
17:26:08 To enter a code, type < * * < on the phone with SIM-card inserted
17:26:09 Turning off the phone...
17:26:11 Done.
! 17:26:11 Please disconnect battery and cable from the phone!
Alternatively you can do this:
hard reset *2767*3855# (this erases all ur data, you can preserve ur data by takin a backup.)
17:26:11 Done.
try these codes .. *#06# Display imei
*#300# OK List the software and hardware version
*#301# OK Full keypads functional test
*#303# OK Set default language to english
*#304# OK Set OFF engineering mode
*#304*19980722# Set ON engineering mode
*#307# OK Engineering test mode
*#311# OK Phone code changed to default code
*#402# OK Adjust display intensity/ contrast
*#403# OK List the manufacturing informations
19980722 OK Master unlock code for phone and simlock
*#302# OK Accoustict test
*#3370# Enhanced full rate
*#0000# OK Settings saved, restore set phone to default language
