Question about W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer
My vax upright rapide carpet shampooer is leaking water everywhere also the trigger on handle seems to be stuck any ideas anyone
    Genius:
  • Vax Master
  • 2,548 Answers
That's your problem the trigger stuck on all the time replace trigger.
Posted on Aug 09, 2014
Anonymous
SOURCE:
Vax rapide ultra 2 draining water tank even when trigger not released
if the seal is dry from lack of use,you may need to put some vaseline on it.
Jul 19, 2018 | W87-Rh-P Rapide Ultimate Clean Upright...
When i press trigger for water,It wont dispense water when hose is attached but i get a water flow when hose is placed over the side,ive checked for blockage in pipe ? Vax135u rapide
Vax135u rapide... UK: carpet cleaner, 4+ stars
Hello Jet Black,
Check the bottom of the clean water tank to make sure it is fully seated... and the hose connections...
Else you have a loose/broken fitting from your "trigger"
VAX Rapide 135U Carpet Washer Cleaner
Vax Rapide Spring Clean Carpet Cleaner 135U
Aug 06, 2016 | Heating & Cooling
My vax rapide w89 will not spray water from the bottom
Hi s_hall9800,
We bought a Vax Rapide Carpet Cleaner and were disappointed with it's performance as we couldn't see it spraying the cleaning soltion onto the carpet. I found there was no pump and gravity was all that put the solution on via a sparge pipe, controlled by a trigger-operated valve. So, all that happened was an intermittent sort-of dribbling. The cleaner picked -up quite well, though and we sprayed the carpet using a separate hand-held sprayer.
Nov 21, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
My vax wont deliver water to the carpet when i pull the trigger
Check the delivery system for kinks in the hoses or clogs in the tank.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Apr 15, 2014 | W90-Ru-B Rapide Ultra Upright Carpet And...
Vax Carpet shampooer leaking
Check seal is clean on the water container and machine!
Feb 01, 2014 | W90-Ru-B Rapide Ultra Upright Carpet And...
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Jun 01, 2008 | VAX Appliances Vacuums
W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Logo
1,770 people viewed this question
Top Vax Vehicle Parts & Accessories Experts
Bigaitch
Level 1 Expert
ray gallant
daf62757
Level 1 Expert
Are you a Vax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
