SOURCE: Cannot open washer and remove console
The console should come off by placing a putty knife under the front corner of the console. Push straight in, while lifting up. The console should pop off exposing two brass colored clips that hold the main body on. Remove the clips and the whole casing should come off the frame. I hope this helps you.
SOURCE: How do I lift the top of a Kenmore 600 series top
Most of them machines the top don't pop. You flip up the controls and release the s-clips on each side and then tip the case towards you to get it off. Some screw down from the front, others have the screw hidden, still others don't have a screw just a clip on each side of the control that can be easily popped with a putty knife.
How it works and 4 main problems HERE
Direct drive 101
Was this helpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: i have a kenmore 600 top loading washer. over
Visit http://appliancejunk.com/forums/ they have more information on this/
