Question about Vizio 39" Class 1080p 60Hz LCD HDTV - Full HD 1080p SRS StudioSound HD
What size screws do I need to mount the VESA to the back of a 39" Vizio?
The screws that came with the mount are too big.
    New Friend:
  • 4 Answers
Most flat screens use 4, 6, or 8mm, be careful not to use too long a screw.
Posted on Aug 09, 2014
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Posted on Mar 31, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: What is the VESA Stardard on the Vizio VO42L 42
400mm Horizon, 200mm Vertical, M6, 1mm pitch screw thread.
It is in the user manual, download it here: http://tv.manualsonline.com/manuals/mfg/vizio/vo42lf.html
Posted on Dec 18, 2009
Amado Petallana
  • 320 Answers
SOURCE: I have 32 in Vizio and am using a full motion wall
To know the exact size of the screw, you have to get the circumference of the hole where you will insert the screw. If possible to bring with you the outer mounting in buying the screw to have a perfect fitting.
Posted on Nov 30, 2010
Rocky
  • 302 Answers
SOURCE: vizio l32 tv stand screw size
The best thing to do is trial and error. Get some sample screws from home depot.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
What type of screw is needed to connect the bracket to the back of my 32inch emerson tv?
You would use vesa screws 4mm x 10mm - for non-recessed vesa mounting holes.
4mm x 20mm + approx 1ccubewi_0.pngm spacer - for recessed vesa mounting holes
Mar 28, 2011 | Emerson LC320EM9 32 in. LCD HDTV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Dec 26, 2009 | Philips 42PFL3704D LCD TV
I have a Samsung LN32A450 and a Peerless SGLs01 mount. I need to put on the universal bracket onto the back of my TV but the back of my TV is not "flat", is more like a small S-curve so the lower part is...
That TV is new enough to have a VESA standard connection on the back, try attaching the mount directly to the 4 screw holes on the back, tv's don't normally need an adapter if the back is fitted with VESA. if not you can find low cost adapter plates on www.etvmount.com for the most part any vesa adapter than matches your size will function fine.
good luck-
Will
www.compressionconnector.com
Feb 19, 2009 | Akai LCT2721AD 27 in. LCD Television
Vizio 39" Class 1080p 60Hz LCD HDTV - Full HD 1080p SRS StudioSound HD Logo
126 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
