Need remote code for all in one remote
Due to the number of possible codes, i find it easier to use the other way to set up the all-in-one and universal remote.. in case the steps are applicable to the one you have, try to press and hold the On/Off button and SET/SETUP button on the remote and once the set up light lits up, release both buttons and then press and hold the Volume up button. Keep holding it while pointing to your tv, then as soon as you see the volume goes up on the tv, press the SET button and test the remote to see if it works. NOTE: this may take a while at times, though if you get lucky, it will just take a couple of minutes.
SOURCE: Remote control code needed
look on the website of you dish company and they should have it listed but i do not recommend programming universal remots on tv as if could change setting that the consumer is not able to change back
