Two black verticle lines at bottom right of screen after bumping television with vacume sweeper
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
SOURCE: Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
SOURCE: 2 year old Mitsubishi LT-46149 46" LCD Flat Panel
Does it come and go? I would try reseting the ribbon cables between the LCD panel and the T-CON board first.
The Flexible Printed Circuit BoardS (FPCB) are ultrasonic welded to the LCD TFT panel, they are not SOLDERED on! The connections do get bad due to very delicate nature of how the LCD panels are made. You can also try squeezing the around the top area of the screen where the lines are to see if the lines go away.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
