Successful repair of my Yamaha Clavinova CLP 880
The principal to replace your contact strip will require one further step to that shown here where the customer has replaced the felts.
When you have the keybed out you will see the contact strip part 220. This is held in place behind the circuit boards. Remove boards, replace strip and reassemble.
It might be worth considering felts whilst you have the keyboard in bits as these wear out.
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=19108
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
