My phone says low space all the time. Even after I take it back to factory. Now I cant get text messages it says its full. I dont understand. Now if I take out the sd card and put a new one in it. Would that help or not. I dont want to loose all my pictures. Help me?????????????????
Data must be enabled on the phone for MMS to function. Also, it's possible that you need to manually configure the APN settings. Your service provider should be able to tell you the correct APN.
From http://www.hard-reset.com/nokia-n70-hard-reset.html
Nokia N70 hard reset
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345. If it is not working try this code: You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
