Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
SOURCE: can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
SOURCE: Not only is my asko washing machine leaking, the
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
SOURCE: LED is flashing F3 while load is in the washing machine
The "F3" for Asko washer`s indicates a problem occurred during pump out or specifically with the pump.
Based on your description of the unit being "full of soapy water" I suspect you have the wrong detergent or too much in the machine. These Asko ( any front load for that matter and some hi efficient top load`s recently ) must be used with lo-sudsing detergent`s only, also known as "H-E" detergent. If the manufacturer`s recommendation to use only "H-E" is not followed the unit will not function properly. ( "H-E" detergent`s do not use nearly as much "soap" as an additive in the detergent thus there should be no or very little suds present with the proper amount, always use half or a third of what is recommended on the detergent container, after all, they are in the business of selling detergent. The more you use is a benefit to them and of little to no consequences...except to you the consumer ) Some symptom`s include not allowing the pump to drain the unit properly, hence creating an error code such as "F3".
You may be able to remedy the error by way of removing the item`s of clothing, add some white vinegar ( this will help neutralize the suds ) and run the washer thru a short wash or rinse cycle. You may need to repeat this procedure to wash away excessive soap buildup in the machine.
You may also need to prewash clothing previously washed with regular detergent or in top load machines to minimize sudsing as well. This is something I suggest to all my customer`s who are new to the front load world.
If this does not remedy the problem and in fact the unit just won`t drain, check the pump for any obstructions in the filter insert/pin trap.
Here`s how to check...
**1. Turn off the power to the machine.
2. Using a flathead screwdriver
or similar item,
gently pry open the
drain pump cover if present on your model.
3. There is always a small amount of water in
the drain pump area. Before you open the drain
cover, place a shallow container, such as a pie pan,
on the floor below the drain to catch the water.
4. Pull the small black drain
hose loose from its position
on the door cover and let
the water drain into the pan.
5. Twist the pin trap cover
counterclockwise and lift it
out.
6. You can now clean out
any grit or small
objects. You should
also clean the pump
rotor at the back of the
pump housing.
7. Replace the drain cover and return the drain hose
to its position on the door.**
These are common issue`s to look for with Asko, or as I alluded to prior any front load machine. You may want to consider calling in an authorized Asko servicer if you are not completely comfortable with any of these suggestions or performing these procedures.
( I don`t know why my font changed nor how to change it back ,sorry not my computer right now it`s a netbook lol )
Hope this help`s solve your problem. If so please take a moment to rate the info I provided. If not let me know if I can assist you further.
Thank you for visiting "fixya" for you Asko inquiries.
Good luck.
macmarkus :)
Testimonial: " Thanks so much to macmarkus. My husband came home, pressed the off button for several seconds and then turned the machine back on. It worked! "
SOURCE: i have an asko quattro
Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
