Question about LG LHX-557 Theater System
Lg lhx 557 home theater syst will stay reading in reading mode an will not play?a dvd
The 5 cd player will play music but when a DVD is placed the syst stays stuckin reading mode? HELP
  • LG Master
  • 924 Answers
Remove the DVDs and try a CD. If that works, your Optical Pickup)laser has worn out.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Posted on Aug 10, 2015
2 Suggested Answers
6ya staff
SOURCE:
dcramer531
Dcramer531
  • 1654 Answers
SOURCE: I have an LG HomeTheater
In the past this has been caused by the laser not reading the disk. This can be caused by either a dirty laser or disc as well as an unformated disc. Most likely your laser is getting weak and is not picking up the info on the disc. I have solved this before by opening the cover on the dvd and simply unplugging the ribbon connector from the circuit board to the laser, leave it unplugged for several minutes before re-connection and then try to use the dvd again. This may clear it up and it may come back. Short of replacing the laser unit in the system, this might help for a while. If this continues and does this on a variety of discs not just one, then you need to decide if you want to spend money on a repair or replacement. If you wish to try and replace the laser that can be done also, but if it were me I would save my money and get a good quality player and you will get a warranty on a newer player. I personally use Sony and have had very good luck in these units. You can also run a cheaper dvd player through the theater system by hooking it up as an outside component thought the audio video jacks on the system.
Posted on Jul 01, 2011
The LG Home Theater has a RESET CODE?
UNPLUG IT FOR 30MIN AND SEE IF IT STILL POP ON
Apr 29, 2016 | LG LHX-557 Theater System
Dvd door will not open says disk error?
Have a look on or around the door flap. There should be a tiny hole that you poke a needle or pin into. That will release the disc tray. The disc may be the wrong type (CD or ??) or it may damaged or like what my Daughter did once, put it in upside down.
Mar 27, 2016 | LG LHX-557 Theater System
JSI JS5001 DIGITAL HOME THEATER RECEIVER/DVD PLAYER w/ 5 Speakers & Woofer
Make sure your speakers and dvd player disk is clean. Skips are common from the lazer reading and will read much better with a quick check on the cd.
May 02, 2015 | home Audio Players & Recorders
LG LHX 557will not play DVDs but will play music
Your Optical Pickup(laser) has worn out and needs to be replaced.
Aug 10, 2014 | LG LHX-557 Theater System
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
Jan 20, 2013 | LG LHT250SC Theater System
No sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
May 17, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
LG home 5 disc dvd changer
defective call customer support or bring it back to were you bought it
Jul 21, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
LG LHX-557 Theater System Logo
109 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
patseamur
Level 1 Expert
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
