Question about Mackie 1604 Vlz3 16 Channel Mixer
Eq for male vocal mic on mackie 1604 vlz3
Having hard time to get good eq on lead vocal need to play a lot with mid frequency which would be best eq for male vocal
  • 36 Answers
6ya staff
SOURCE:
Anonymous
SOURCE: hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Posted on May 26, 2009
Fred Yearian
  • 5603 Answers
SOURCE: i just purchased a mackie 1604 vlz3 and am trying
The user manual has fairly good diagrams.
Get user manual here:
http://www.mackie.com/products/1604vlz3/pdf/1604VLZ3_OM.pdf
On page 34 is the BLOCK layout which has everything you need to know, once you figure how to read it!!!
The Triangle symbols are operational amp/analog summing amps.
By looking at the jack symbols you can tell if they are mono or TRS.
A lot of the TRS ones will show a TRS three lead jack but have a resistor to ground. These can be used as mono's.
The TRS (stands for Tip-Ring-Sleeve) connectors are used in two ways. One is as a balanced input where both the signal and its inverse is used. A balanced line is far more noise free and ground loop free than an unbalanced line.
Another use of the TRS is for external effect insertion where the sleeve is ground and the tip is the signal SENT to the external effect box and the ring is the RETURNed signal from the effect box.
SOMETIMES you may have to make your own cables to get the signals where you want them on the connectors.
HINT: Use XLR connections wherever you can. More rugged, balanced and noise free- ground loop free.
Posted on Dec 16, 2009
Fred Yearian
  • 5603 Answers
SOURCE: Mackie 1604 vlz3 loose knobs
If these are the rotary knobs, pull them off and compare the shaft to one htat is tight. Sometimes it is a split shaft and you can GENTLY bend them out the tiniest amount to tighten the knobs.
If the shafts are plastic, try putting a few strands of thin string across the shaft before putting the knob on.
the knobs pull off but take a bit of forcee to do so.
IF IT SEEMS that the shaft itself is looser than others, best leave it alone. Replacing a pot on these takes a lot of work... MANY knobs must be pulled off and the case opened and at least a section of the board with the pots removed to access the pots.
Posted on Jan 12, 2010
barbu51
Jacques Marin
  • 566 Answers
SOURCE: Mackie 1604 VLZ3 Issue.
Hi kielhunt
It sounds like power supply issues.
You may have bad capacitors and/or bad regulators.
If you have a multimeter you can get in there and check the dc voltages for ripple(ac voltage mixed with dc) or over/under voltages along the +/- 15volts lines.
Good luck
Posted on Jan 20, 2010
Testimonial: "Good ideas, even though he didn't know the answer to the issue fully he was well rounded enough to give great ideas for in-house solutions!"
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: I need to know step by step how to hook up my
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Posted on Nov 25, 2010
How to connect bass power subwoofer
Totally depends on the sub and if it has a crossover and if so what sort and if it has a pass through either for mid/tops or parallel. If it has a low pass then take mixer main out to sub, if mid top output then mid top to that, if only pass through then either full range to mid top from there or probably need crossover in signal path to split the frequencies.
Jan 30, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
There is no easy answer to this. It will depend on the mic, the speakers and the singer and genre amongst many other things. It will also probably be room dependent too although the overall eq should be able to take this out of the equation to a large extent.
Your best bet is to get someone to sweep the frequency on the mid range with a bit of positive and then a bit of negative eq to find where most affects your vocals then fine tune to your liking. Are you using a bit of reverb/chorus/echo as his can often, when used sparingly, enhance even a good singer. The biggest difference you'll probably find is from using different mics. The ubiquitous SM58 does not suit everyone but is robust, warm and forgiving but if you're after a more pure sound there are many more accurate mics you can try.
Aug 10, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
How to setup a vocals
Turn gain CCW. plug microphone in, mute the channel. turn gain CW until peak LED flashes (while singing loud!) and turn gain back a little bit.
Take the channel fader down, unmute the channel. Put masters at 0dB (near maximum) and adjust the loudness with the channel fader to what you like.
EQ: it always depends on your location. Keep it flat. You might like to reduce at about 200-300 Hz. Cut the low end (Hi Pass Filter = on) or if no HiPass reduce "bass" for about 6...10dB.
ok?
Mar 29, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3, M-audio Delta 1010LT With Cubase 5 . There is a main problem when it's normal with an apm it's no problem no sound problem but when the direct out is working with the sound card the...
You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
Jan 18, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Hi kielhunt
Good luck
Jan 20, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I just purchased a mackie 1604 vlz3 and am trying to figure out where all the parts and wires go to and how do i know if a trs is required or just mono ect... i have a compressor/effects/bbe/wireless mic/...
Dec 16, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
My mackie d8b just stop picking up any input signals what could the problem be?
Make sure the mic/line button is selected when trying to input from teh external inputs.
Nov 01, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Hooking up powerd monitors to a Mackie 1604 VLZ3
Apr 04, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
