f the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
Never force it, just use the remote. If it won't stay in, unplug the unit and wait a while. I think we get viruses from the TV signal which might be temporary (hopefully).
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit 2) Insert VHS tape 3) Insert DVD-+R or DVD-+ RW 4) Using remote, press VCR 5)Using remote, press play then pause the tape where you want to start recording. 6)Using remote, press DVD 7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
On your remote Press the System Menu botton when open scroll down to Setup, press Enter, scroll down to Video and press enter another menu will open. Scroll down to Personal and press enter and play with settings while watching the Video you want to make changes to, until you are Satisfied__!
I was unable to find the code for that specific cable box. The TV was no problem, And I couldn't find the combo code, but I have the Sony VHS code and DVD code. Maybe they'll work.
Sony TV: 002, 006, 071, 128
Sony VHS: 004, 099,128,139,140,141,147,154,155
Sony DVD: 009, 174
I hope this helps!
what happened was that you probably chose a disc speed on the DVD that was too fast or slow for the dvd players that you are putting it in to. Try re recording it but when under the DVD section, on your remote, choose REC Mode till it says SP. That one should work on just about any dvd player. I had the same problem with mine. Here is a step by step instruction on how to dub from VHS to DVD correctly. If you follow all the steps, you should be fine :)
http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
Sorry David you'll need to get a replacement remote. Not the answer you probably want but that's the only way you're likely to close the sessions, unless someone has written some software that can do this. I had a problem with my funai with unclosed sessions and I had remote but laser needed adjusting
you may not need a remote to dub a vhs tape to dvd.
look on the front of the recorder. see if there is a arrow showing dubbing vhs to dvd/ dvd to vhs. since you do not have the manual, you'll probably have to play around with it a while to figure it out. you will also need to know which format the dvd will record on. [dvd-r,dvd-rw,dvd+r,dvd+rw or ram] you can look up your recorder brand & model # online, then search for a manual you can download.
good luck.
wg
