Tablets & eReaders Logo
A
Anonymous Posted on Aug 11, 2014
How to reset apple ipad
How to reset
John Jayson Samson
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Aug 12, 2014
John Jayson Samson
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
1798
Points
29
Hi Anonymous,
I think this may help you,
  1. Make sure the iPad battery is charged above 20% ( we would recommend at least 40 - 50 %). If you are not sure charge you tablet for at least 30 -40 minutes.
  2. Make sure iTunes is not running on your computer but is ready to be run.
  3. Temporally disable firewalls and other security software to prevent interference with iTunes.
  4. Make sure your tablet is disconnected from the dock or USB data cable that equips the gadget . Nevertheless USB cable must be plugged into your PC or MAC.
  5. Make sure your PC or MAC is awake and its screen saver is turned off.
  6. Simultaneously press and hold down the Wake/Sleep button and the Home button and wait until "slide to power off" screen appears. Don't do anything after its appearing, just keep holding Wake/Sleep and Home buttons until Apple tablet will power off.
  7. Release the Wake/Sleep button once Apple tablet is off , but continue to hold the Home button
  8. Holding the home button, connect the USB data cable to iPad. When you reconnect the USB cable, tablet should power on and you should see a message on your PC/MAC display saying that iTunes has detected an iPad in Recovery Mode
  9. After you detected this message, release the home button and press OK on iTunes pop-up to confirm the restore option.
  10. Do not touch iconic tablet and you computer while iTunes downloads and installs the fresh copy of firmware on your iPad. You will be notified by iTunes when iPad is successfully restored, but... in a while, you will get an message saying that the iPad isn't recognized. Don't panic. This is because all user content on iPad including activation status was erased during restoration.
  11. Disconnect iPad from iTunes ,unplug from computer and turn off.
  12. Turn iPad on and using iTunes activate it on any computer you have. Apple currently allows up to 5 computers to be authorized for each iPad.
I have an ipad mini that's frozen on the apple logo.I've tried everything.I wanna factory restore the ipad but in order to do that I have to be connected to the internet.
Hi:
Try a hard reset. It forces your iPad to turn Off and then On.
Hard Reset Your iPad. A hard reset forces your iPad to abruptly turn off and back on, which will usually fix the problem if your iPad has frozen on the Apple logo. Press and hold the power button and the Home button simultaneously until the Apple logo appears. Then, let go of both buttons.
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
How to hard factory reset an apple ipad, don't have passcode
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. Reset iPadsettings.16 Apr 2013
Apple iPad hard reset
www.hard-reset.com/apple-ipad-hard-reset.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=hard%20reset%20an%20apple%20ipad
1helpful
Setting up gave wrong email will not let me fix it
Barry, You may have to do a factory reset and start over, or contact manufacturer for suggestion.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple iPad mini Retina How to master reset
Perform factory reset Apple iPad mini 2 128 GB
How to Easily Master Format APPLE IPAD MINI 2 RETINA DISPLAY with Safety...
How do I reset my Apple ID and password on my apple iPad Air without boot disc or iCloud password
Follow these steps to reset your forgotten Apple ID password: https://support.apple.com/zh-cn/HT5787
How can I remove a previous owners Apple ID from an iPad?
You need to either connect the iPad to iTunes and select "set up as new iPad" or you could also reset your iPad by opening settings/general/reset and choose "reset all content and setings". Both ways will delete all apps and you have to purchase or reinstall them.
How do i factory reset apple ipad i forgot my apple id and password
Resetting the ipad will not help... The I'd and password are stored at the apple store.
How to reset my apple ID on my I pad
This needs to be reset by the Apple ID that first setup the Ipad. If you don't have that - you can take the Ipad to an Apple Authorized Service Center - along WITH a receipt or proof that you own the Ipad - and they can reset the device for you.
Can't reset the iPad without the pass code
this is apple's lock, i will not want someone to open up my iPad if it is stolen, if not contact apple directly they will assist you after some checks, remember that the code can be reset if you know the apple id and password for that iPad.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
