Symantec Norton AntiVirus 2008: Windows Logo
A
Anonymous Posted on Aug 11, 2014
[email protected] unauthorised removal of funds from my bank acc.$.99.99. The code referring to the withdrwal is as follows--Norton AP 228782511 Next numbers are--080-017-4089 GB.The Bank tells me Paypal were involved in this payment again without any authorisation.I can only consider this transaction fraudulent and will be disputing it. G.McCombe
Dan Justice
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Aug 17, 2014
Dan Justice
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
1164
Points
17
Did you buy Norton Anti-Virus? If not then someone may have used your account to pay for Norton. I would talk to your bank about getting the funds back. I really do hope you're able to get this problem resolved with your bank, though no one here can really do anything.
1helpful
I sent money but put the wrong name but right sort code and account number is that alright
Hi
That should be fine, the name is just for a reference on your bank statement and the person your sending the funds to. The acc number and sort code are the key factors.
I hope this helps Nick
Are there any surplus money in the nei pension fund?
Contact them.
FIXYA is for asking and answering questions.
Volunteers should not be given your personal financial details, and do not have anything to do with pension funds, banks, or government institutions.
https://www.pensionfund.co.za/fund-administrators-and-the-funds-they-administrate/old-mutual-life-assurance
Feb 05, 2018 • Finance
2answers
Swift code for kiwi bank in invercargill new zealand
If the sender wants to make a payment to your Kiwibank account from their bank's internet banking, there may not be enough fields for them to enter both Kiwibank's details and Citibank New Zealand's SWIFT code. In these cases, the 'Kiwibank Limited' details can be left out, but the sender must make sure they quote the '38' at the start of your account number. The '38' identifies your account as a Kiwibank account, so Citibank New Zealand know where to send your money.
If the sending bank has an existing relationship with another New Zealand bank, they may choose to send the funds through that bank instead of Citibank New Zealand. The funds will still be credited to your Kiwibank account, but the fee deducted by other New Zealand banks may be higher than the fee we charge through Citibank New Zealand.
You may be asked to provide extra information, like BSB numbers, sort codes, routing codes or IBAN numbers - these are just different terms used overseas for bank, branch and account numbers. Your full Kiwibank account number starting with '38' includes these details.
Account name: The full name of your Kiwibank account
Account number Your account number is 15 digits in total.
Receiving Bank: Citibank N.A, 23 Customs St, Auckland, New Zealand
SWIFT code*: CITINZ2X
Correspondents: Use Citibank NZ correspondents for all currencies
Other information/reference: Include 'forward to Kiwibank'
* The SWIFT code belongs to Citibank New Zealand, which accepts payments on behalf of Kiwibank.
I have a 2004 Ford F150 4x4 Lariat with 99,949 miles on it. The truck started shuddering about 1 month ago after replacing the serpentine belt. A mechanic suggested that I change the spark plugs using OEM...
code p 0021 refers to camshaft position sensor (CMP), intake /left /front , bank 2--timing over advanced /system performance ====causes --valve timing---engine mechanical fault -- CMP actuator
change the can shaft actuator , not the position sensor
code p 0175 refers to system too rich---bank 2===causes --intake blocked ---EVAP canister purge valve ---fuel pressure ---EGR system---injector/s HO2S ( heated oxygen sensor in the exhaust manifold before the cat converter bank 2
code p 0345 refers to CMP sensor A bank 2--circuit malfunction===causes wiring ---CMP sensor ECM
check the wiring for breaks
code p 0325 refers to knock sensor ( KS) 1 bank 1---circuit malfunction==== causes wiring---poor connection to KS---KS
code p 0171 refers to system too lean bank 1===causes --intake /exhaust system leak---AIR system---MAF/VAF sensor ---fuel pressure /pump---injector/s ---HO2S in the bank 1 exhaust manifold before the cat converter
find an accredited service center with experience on the vehicle and have it fixed
I want to have my paypal go to my debit
If I understood your question right you want to withdraw your funds to your debit card. If that's what you mean you should have completed the following first:
- Verify your Paypal by following the instructions on the paypal site. usually you need to add your debit card first by using the debit card number not the debit bank account number
- If already verified Add the same debit card on your paypal by clicking Profile then add bank account. This time use the debit card bank account number. You should also know the bank code for paypal. You bank can tell you that.
Now if you want to withdraw your funds you just need to click withdraw menu then choose the debit card bank account you just added.
How do i download my antivirus to a second computer
if you are using norton 360 premier version go to the following site
www.norton.com/n360p_4
you can download and install the product
if you are using norton 360 standard edition then go to the following site
www.norton.com/n360s_4
from there you can download and install the product
after installing the product insert the product key to actiavte the product
Thank you
I have had my paypal account limited and I wish to draw funds out of it. How do I do that?
Login to your Paypal account. If you don’t have a Paypal account yet, then sign-up for an account.
Once logged in, click the Add/Edit Bank Account link by hovering over the Profile link under the My Account tab.
Click the Add button to Add a Bank Account to your Paypal Account. In this step, you simply have to accomplish the form with the following information:
Country
First name
Last name
Bank name
Bank code
Account number
You can easily fill in all the information, except maybe for the Bank code. I got the list of bank codes from http://pages.ebay.ph/bankwithdrawal/bank_codes_ph.html. As indicated in the Paypal instructions, your bank account in the Philippines should be able to receive payments in Philippine Pesos.
Once you successfully added a bank account to your Paypal account, click the Withdraw link under the My Account tab.
Paypal offers two options for withdrawing funds from your Paypal account: Withdraw funds to your bank account and Withdraw funds your card. Since I did not know what will happen if I chose the second option and I did not have a debit or prepaid card, I clicked on the first option.
Have a great day,
Bhautesh
4helpful
Trigonometry(height and distance)
PA = 7 meters
ð A=600
Given Tan 60 = 1.732
Tan A = TP/AP
TP=AP*Tan A
TP = 7 * Tan 60
TP = 7 * 1.732 Meters
TP = 12.12436 meters
Zulfikar Ali
Top Symantec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
