After I fitted new battery my fhone turns off and on by itself every two minutes
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
