Blinks 14 times
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
SOURCE: sony bravia goes into standby
standby light flashing is an indication that tv needs service. it prevents the tv from further damage. go to www.eservice.sony.com to check service options
SOURCE: I have a 2008 Sony
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times.
Please help me troubleshoot this problem so I can order the correct part to fix this television
