Frigidaire gallery throwing code
Thank you for your post, Friend.
Typically error code SY CE, indicates an issue between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
SOURCE: Frigidaire Gallery side by side
Hi If you have unplugged the unit for at least 5 minutes and the
error code keeps coming back then this will be a warranty concern. Any attempt
by you to correct the problem aside from resetting the unit (unplugging it for
5 minutes resets the main control board) will void your warranty.you have to
call the dealer or frigidiare service center. Please get back to us if you have further query else please accept the
suggestion.
Thank you for contacting fixya.com
I appreciate your post, Carol!
Based off the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and the lights are not working. A "SY CE" error code stands for a communication error at start up. This might be a miscommunication within your refrigerator and I would recommend performing a reset in order to correct the issue. To reset your refrigerator you need to disconnect power from it for roughly ten minutes. If this does not help correct your issue you may need to change your control panel or a wiring harness. In order to properly diagnosis your refrigerator you may need to disassemble it and I would suggest having a professional technician out to do so. This will help you avoid any unnecessary part purchases or personal injury. -Matt
Thank you for your inquiry, Carlos!
From the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and you would like to know the meaning. The error code "SY CE" stands for communication error at power up. This could be an issue with your wiring harness, main control board, or user interface board. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Good morning friend, I appreciate your post!
I understand that you are trying to reset your control panel on your Frigidaire refrigerator because is it displaying the SY CE error code. To reset your appliance you would need to disconnect power from it for ten minutes. You can do this by unplugging your refrigerator or flipping the household circuit breaker. I hope this information is helpful. -Matt
Hi John Dirksen- Could the error code possibly be SY CE? If so, it typically means that the unit has detected a communication error at power up. A professional will need to check the wiring between the main control board and user interface. Depending on the diagnoses from the professional either part may need replacing.
