The ringer is silent and I cant hear anybody on my speaker phone but they can here me
SOURCE: problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
SOURCE: Stuck on silent mode and cannot get the ringer to ring
All you have to do is hold the pound (#) button down. It will then say exit silent mode. If you ever want to put your phone back in silent mode, just hold the pound (#) button down.
SOURCE: to put my giorgi armani samsung on to silent
on the top left corner there is a sound icon. touch it with your fingertip. just keep your finger on the icon for a few seconds and u can activate or deactivate silent mode
SOURCE: blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
SOURCE: phone went into silent mode for ringer cant seem
Go into settings and sounds and slide the slider for ringer volume all the way to the right.
