Remember its whats inside that maters - I will never ever again buy another Maytag!
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Here is a link for you !!!!!!!!!!!!!!!!
https://www.youtube.com/results?search_query=Maytag+Bravos+Washing+Machine+Error+Code+F1
SOURCE: F1 error code
This was copied from a website called WORLD OF WASHERS....I just copied the whole paragraph......sounds like some $$$
Let me know if this helps.......mtg
I am new to this online blog stuff, so I figured an email would be
best. I own a Kenmore Elite Oasis washer Model #110.27042602. Everytime
we try to use the washer we get error code F1 flashing. This happens
withins seconds of the machine first starting to fill and about ten
times thereafter until enough water gets into the tub for balance, I
assume. We have started pouring about 2 gallons of water onto the
clothes in the tub by hand before starting the machine which usually
works. About half the time the machine stops again between wash and
rinse cycle as it starts to fill with water again.
In my online
research, I guess its good we don't have error code F51, but this is a
pain and 1 year warranty has passed. It appears I may need to get a new
Machine Motor Control Assembly. Any thoughts????
Thank you,
Darrell S.
Darrell,
I'm
probably not going to tell you anything you don't already know. You
know you may have to replace the motor control assembly, so you have
done your due diligence.
I found a thread related to your problem at the "Samurai Appliance Repair Forums" at ApplianceGuru.com.
That link will take you to the discussion, in case you haven't already
read it. The poster described a situation identical to yours, and I
have also read of this problem at other sites on the web.
Contained
within that thread is a link to a Service Matters (Whirlpool Corp.)
tech sheet related to the F1 error code. This is the document any
qualified servicer will refer to when addressing your problem. Here is a link to that sheet in case you want to have it on hand in the event of a service call.
The
tech sheet calls to replace the control, but only after three other
tests have been conducted. Everything I have read indicates the control
will be replaced the vast majority of the time. I am not a technician,
but I would say there really is no way around that.
Please keep
in mind that this sheet applies to specific models and serial numbers
within the Whirlpool line. There may be a separate sheet for your
washer, but I imagine the end result is the same.
The million
dollar question is how much will such a repair cost. I am seeing prices
ranging from $150 to $200 just for the part. With labor, you will
probably have at least $300 invested in this repair. I would encourage
you to contact Whirlpool at 866-769-7260. I have read instances of
other owners receiving satisfactory service in out-of-warranty
situations via this number. Whirlpool knows these washers are ****, so
they no doubt have a scripted procedure in place to deal with these
situations. Be firm, but also be polite. Maybe drop the word "recall"
and see what happens.
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
SOURCE: The f1 code on the Maytag Bravos top loading
Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
SOURCE: My Maytag Bravos quiet series
Hi and welcome to FixYa, I am Kelly. "Ld" (Washer is taking too long to drain water from the wash tub) Check the following: Is the drain hose kinked or clogged? Is the drain hose installed properly? See "Connect the Drain Hose," page 2-5. Press Is the drain hose clogged, or the end of the drain hose more than 96? (244 cm) above the floor? a) Loosen the clamps and pull the inlet and outlet drain hoses off the pump. Note that there is a tab on the outlet connector that fits into a slot in the hose. b) Remove the three 5/16? hex-head screws from the drain pump and remove -Disconnect the wire connector from the drain pump terminals. - Set the ohmmeter to the R x 1 scale. - Touch the ohmmeter test leads to each of the drain pump terminals. The meter Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96? ? • Is the pressure hose connection from the tub to the machine/motor control pinched or plugged? TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps. See take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power.Replace the machine/motor control assembly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
PAUSE/CANCEL to clear display
Also:
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
• Is the pump running? If not, see TEST #7.
TEST 7
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
Perform the Manual: Pump test.
