Uniden BCT15X Beartracker Scanner Logo
randy duncan Posted on Aug 12, 2014
HOW DO I GET IT TO SCAN THE FREQUENSES I ENTERED
Wilfred guilbeault
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Jun 06, 2019
Wilfred guilbeault
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
Helped
10718
Points
6
How do we sconne frequency channel in a uniden scanner bct15
CAN NOT PROGRAM NEW KEY FOR 2008 TOWN AND COUNTRY
RESET AND REPROGRAM ALL KEYS, CAN ONLY DO A SET NUMBER, I THINK 8 KEYS. START OVER CLEAN
2helpful
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
The waste ink absorber is almost full
1. Power on
2. Press Menu, then SCAN, COPY and SCAN - you entered service mode.
3. Choose NVRAM ACCESS then ??.
4. Choose SET ABS-M LEVEL and set it to zero.
5.Choose SET ABS-? LEVEL (if exist) and set it to zero.
6. Power off
1helpful
2answers
Scan to e-mail
Hello
To be able to scan to email, your machine must have the correct hardware.
The following addon board and kits must be fitted:
1 Network Printer Kit [In South Africa we use the GA 1190]
2 Scanner Upgrade Kit [In South Africa we use the GA 1200]
3 Extended Keyboard [In South Africa we use the GJ 1040]
Once the hardware is fitted to the machine there are a few more steps to follow:
1 The machine must be connected to the network. [network must be on the internet]
2 An IP address, Subnet Mask and the Default gate way must be entered in the machine.
3 The DNS server must be entered through your internet browser.
4 The SMTP address must be entered through your internet browser.
5 The SMTP client must be entered with a valid email address through your internet browser.
6 The email section must be setup in the internet browser.
That should do it for you.
Regards
I have entered a few frequencies into my scanner and now i am trying to get them to scan. I press the scan button and it will scan a channel one at a time, but i would liek for it to scan all the...
Your BC72XLT SCAN feature samples one frequency/channel at a time, but it should only stop on active frequencies. If it's stopping on inactive frequencies you may need to adjust the squelch. For more details on programming and operating your scanner you can download and print the factory manual, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Listening in since the 60's
2helpful
2answers
I need to know frequencies and how to program a bearcat 148xlt
To program the Bearcat 148xlt, press the manual button and then enter your code, for example:"123.456" after you enter the code, push E and then press the manual button again to enter a new code like "567.987" then press E, when all of your codes are entered press the scan button to finish. Try http://www.scannermaster.com
or http://www.radioreference.com for some frequencies to add to your scanners database
1helpful
E-mailing scanned documents - step by step
Has your MFP been setup to scan to email?
It will require a valid email address and the server settings entered into the Network configuration.
DL the manual:
http://help.bt.konicaminolta.ca
Once configured it is a simple matter of entering the email address and pushing "scan".
The scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
