Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
SOURCE: ERROR CODE E3
Here is what it says in Maytag's Technical Info Guide:
Machine control is
check shows motor is not
moving. (Locked, Hall
Sensor fault)
Here is the web site for the guide:
http://www.servicematters.com/maytag_library/docs/16026736.pdf
Try this: take off the back panel and check the motor connections. Unplug them and look for any corrsion.
Hope this helps.
SOURCE: e3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
SOURCE: E3 code showing sometimes on Neptune MAH-3
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach
Possible causes of ‘E3’ codes:
2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a
separate part, but rather an integral part of the motor.
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
