Scan these three barcodes from the LS2208 Product Reference Guide:
Scan Options
Data Suffix
Enter
The scanner will then be programmed to send an enter after every barcode you scan.
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/5880809a.pdf
SOURCE: Enter function
Hi Lee, It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual. eg Scan the barcodes - Send All Data, Send Enter Key, Send Enter Key, Save
SOURCE: When i scan a barcode why do i have to push enter?
Go to http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201bpdf&sliceId=&dialogID=111756507&stateId=0%200%2011492385
This is the quick start guide for the LS2208. On the first page you will see a section titled Carriage Return/Line Feed. Scan these three bar codes from top to bottom. That's it.
SOURCE: i want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
SOURCE: Barcode line enter problem
This is a custom setting. You will find on the user manual (and also at the bottom of the Quick Start guide) a special barcode that, when scanned, toggles between "CR after barcode" and "No CR after barcode".
Hi Lee,
eg
Scan the barcodes -
