I turned it on, had picture, changed channels still had picture then it went black. sound is just find. using the remote volumn by ear and channels by memory. the programming or channels do not show up on screen. The has not been any warning issues either. I live in Florida and recently we have had severe thunder/lighting storms, but nothing with a direct hit. That was a day or so ago. Any Idea if I can reset it or not? help, please
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
SOURCE: Sanyo Plasma Tv Black screen
I had the same problem and Sanyo does not make parts for this model anymore. Luckily I had the extended warrantee so they reimbursed the full purchase price.
Weird that the poster above mine was able to get a part; I was told the part is no longer available.
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
SOURCE: my sanyo 42 plasma screen just went black..can hear it but
Ur Tuner Signal board it dead,must replaced this board.
SOURCE: My new Sanyo HDTV LCD won't come on, although the on light is on.
If your Tv is in warranty or you have a cover plan, you need to return the Tv for repair or replacement.Your Tv sounds like it has a power supply fault.
SOURCE: 42 " flat screen Sanyo. no picture no sound, power yes!
The main board should be checked. For more details Type in this site name < Electro-help> (DO
NOT copy and paste the site name from here.
Doing so may lead you to wrong place) to search box of your search
engine [not in the address bar of your browser],
and press "Enter".
It is an electronic
equipments service help site. Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
You can locate this site,
either at the bottom part of first search page, or at the top of second. Detailed descriptions are there to help you. Check the associated ads related to electronic spare parts. You might get details about the availability and price.
