We have a Thetford fridge in our caravan and is displaying fault code 13. In the manual it says it goes into (BOS) backup mode. Does this mean the fridge will still work until we can get it fixed?
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
SOURCE: I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
SOURCE: fridge light does not work nor the display inside
Yes , the bulb lights up a fiber optic strand , which runs to the display . No light , no lighted display .
Testimonial: "many thanks for the infoe first class"
SOURCE: N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
SOURCE: Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
