It's not failing to pump out yet, but it is squeeling
SOURCE: Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
SOURCE: Fisher & Paykel GWL15 washer won't drain. A
Hi There,You could bail out as much water as possible,Then If you lean the machine back against the wall,(with machine unplugged) you could remove the bottom plate (if fitted) and you will see the pump with a fan attached,Try turning the fan back & forth it may loosen the obstruction and you could then pump the water out before removing the pump for a service,A the front of the pump you will see a small plastic locking clip that needs to be held out while you turn the pump anti-clockwise for removel.Note treat everthing to be live on this machine if plugged in.(unplug machine before attemting any procedure) Best Regards.
SOURCE: how do u replace the agitator on a fisher &
Disconnect power then lift the lid open. Pry the dispenser assembly off the agitator top then remove the agitator bolt by turning it counterclockwise. Once the bolt is off, lift the agitator then install the new agitator in place. Secure it with the agitator bolt then put the dispenser assembly back into position. Lifting the basket helps budge the agitator and remove it more easily.
SOURCE: fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
SOURCE: GWL15 Fisher & Paykel washer doesn't rinse and spin
see this causes and fix it.God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating.
This is easy to check. You will need to remove the switch, this varies
with model type but the testing will be the same. When the lid is closed
the switch should have continuity when the lid is opend the switch
should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or
disassemble to access the motor. Check the leads from the timer to the
motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer
to access the motor. First you can check the motor windings, to do this
remove the plug and connect ohmeter to terminals. Refer to the tech
sheet or service manual for the proper reading. Check motor for shorts
by connecting ohmeter to terminals and motor housing should have no
continuity. Connect voltmeter to motor wire connector and check for
voltage. You should have 120 volts, if you do and the motor does not run
replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check
for black soot from belt wear. Replace if it has excessive wear or
broke.
Motor Coupler
This is a fairly common problem with direct drive machines but
inexpensive and easy to replace. The Motor Coupler transfers power from
the motor to the transmission. The following video will walk you through
the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor
and then turn tub inside. If it spins freely with no noise the problem
is elsewhere. If it is noisy it needs replacing this is expensive and
depending on the age of your machine you may not want to replace it. On a
belt drive remove the belts and spin tub.
