Frigidaire FGB24S5A Gas Single Oven Logo
A
Anonymous Posted on Aug 13, 2014
F11 error code
T will not turn on flashes F11
  • Official Brand Answer 2,267 Answers
  • Posted on Aug 19, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289289
Points
2557
Thank you for your post, Friend.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
1 Related Answer
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Nov 13, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    How to fix frigidaire wall oven beeping error message f11
    Good Morning Friend,
    I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
    -Best Regards-
    WP
    My frigidare oven shows f11
    Hello Jaime, I am happy to assist you!
    Typically error code F11 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
    Best regards!
    1helpful
    I get a F11 code with beeping noise and the oven controls won't work? what can i do?
    Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    4helpful
    Error code f11
    I do not know what the error code f11 means on your appliance but I do know that if you cannot find it in your manual you will obtain the information you require from the manufacturer or a reputable dealer or service engineer. If this error code relates to an open door and you are satisfied the door is properly closed then the switch that closes the circuit that permits your oven to operate is not operating. This may be due to the oven door seal stiffness being just enough to keep the switch contacts apart or it may be due to dirt or grease preventing a clean electrical contact being made.
    3helpful
    F11 error code - frigidaire electric overn
    Disconnect power for 30 sec, then turn it back on
    Top Frigidaire Ovens Experts
    ZJ Limited
    ZJ Limited
    Paul Carew
    Kell Le
    Level 1 Expert
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
