Question about Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System
HOW CAN STOP THE BEEPING ON THE CHAMBERLAIN 3/4 WHISPER DRIVE
  • 2,119 Answers
This manual may help. Check the troubleshooting section.
http://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4242.pdf
Posted on Aug 14, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Posted on Dec 17, 2009
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
SOURCE: door would not close all the way
DOES IT REVERSE OR STOPS BUT NOT TOUCHING THE FLOOR?
IF IT DOESN'T TOUCH THE FLOOR YOU EITHER NEED TO ADJUST THE DOWN TRAVEL OR LENGTHEN THE CONNECTING ARM.
IF IT REVERSES YOU NEED TO DETERMINE IF IT IS THE SENSITIVITY OR THE SAFETY EYES.
Posted on May 27, 2010
blanchettohd
robert blanchette
  • 143 Answers
SOURCE: The belt on my Chamberlain Whisper Drive dipping
Where the belt attaches to the trolley carriage which attaches to the door there is a black adjustment nut with a spring on it. Tighten it up more by turning it clockwise until the belt tightens up. The belt will droop a little when the door is all the way shut normally but should not during operation. If you tighten it up too much the belt will slap on the rail during operation. Make sure the spring is set on the adjustment screw too. This holds the belt tight over time. Thanks BB
Posted on Oct 11, 2010
juozas_v
  • 15 Answers
SOURCE: How can I disconnect the motion detector on the
There is a button on the side of the wall-mounted remote. It has a pic of light bulb next to it. Press it once - the motion sensor is on and the lights will be on once it senses the motion; press it again and the motion sensor will be off.
Posted on Nov 01, 2010
reddawgesq
John Grant
  • 134 Answers
SOURCE: My chamberlain Whisper Drive HD600
Probably just a burned-out light bulb. The "click" you hear is the relay closing. Replace the bulb. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 02, 2011
Why is my chamberlain opener showing an orange light and beeping?
That tells you the opener is running on battery power and that the battery is getting low. Check your outlet and make sure you have power going to it. Could be something a simple as a tripped breaker.
Jul 29, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain Whisper Drive 3/4 HPS Garage Door Opener beeping
Change battery , not change battery the unit will not operate if there is a power failure.backup operation. 5 years is a long time on a disposable battery.
May 11, 2017 | Chamberlain 3/4-HP Whisper Drive Plus...
Opener is beeping
This is a problem with your battery back up. Check the manual for advice, but more than likely if the opener is running well and it is beeping the battery can't take a charge because of a faulty connection or failure. You can get replacement parts at chamberlain.com. Thanks BB
Aug 15, 2010 | Chamberlain 34HP Whisper Drive Plus...
Chamberlain silent 3/4 hp red led on side and hear beeping sound garage door opens and closes, but the beeping sound is annoying? what is causing it
This beeping is actually the battery back up unit making this sound. It either means there is no power to the outlet and it is using stand by power or that something is wrong and the battery is not charging correctly or will not take a charge. You can order replacement parts at chamberlain.com. Thanks BB
Jul 02, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
May 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Intermittent beeping sound
Check the main battery,it might be dead,beeping sound it a require a another battery.
Apr 14, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System Logo
1,128 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
Ross Metcalfe
Ross Metcalfe
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
