In the Panasonic PV-GS85 palmcorder, there is typically a manual release option for the cassette mechanism. Here's what you can try to manually release the cassette:
Ensure the palmcorder is turned off: Make sure the power is turned off before attempting any manual release.
Locate the manual release switch: On the palmcorder, look for a small lever or switch near the cassette compartment. It is usually labeled "Eject" or "Manual Release."
Engage the manual release: Use your finger or a small tool (such as a pen or paperclip) to gently slide or press the manual release switch. Apply gentle pressure in the direction indicated (usually towards the open position) while pressing the switch.
Open the cassette compartment: While holding or engaging the manual release, try to open the cassette compartment by gently pulling it open. The manual release should override any locking mechanism and allow the compartment to open.
If you suspect that your JVC camcorder may have been damaged by plugging in the wrong power cord, it's possible that the cassette mechanism may not release as intended. However, you can try the following steps to manually release the cassette:
Turn off the camcorder: Make sure the camcorder is turned off and unplugged from any power source.
Locate the cassette release button: The cassette release button is usually located on the side or bottom of the camcorder near the cassette compartment. It may be labeled "eject" or have a symbol that looks like a triangle with an arrow pointing up.
Press the cassette release button: Press and hold the cassette release button for several seconds to see if it releases the cassette. You may need to press it firmly or use a pointed object like a pen or pencil to press it.
Manually release the cassette: If the cassette release button does not work, you can try manually releasing the cassette. Look for a small hole on the camcorder near the cassette compartment. This hole may be labeled "emergency release" or have a symbol that looks like a triangle with an arrow pointing down. Insert a straightened paperclip or similar object into the hole and press gently to release the cassette.
If you are unable to manually release the cassette, it's possible that the camcorder has been damaged beyond repair.
If the cassette door/slider on your Sony CMT-HPX9 stereo system will not open, it could be caused by a few different issues. Here are a few things you can check:
Check the release button: Make sure that the release button is being pressed properly and that it is not jammed or stuck. If the release button is not functioning properly, the door will not open.
Check the door lock: Make sure that the door lock is not engaged. Some models have a door lock switch that can prevent the door from opening.
Check the tape inside: Make sure that the cassette inside the deck is not jammed or stuck. This can prevent the door from opening.
Check the mechanism: Make sure that the mechanism that opens the door is not damaged or jammed. If the mechanism is damaged, the door will not open.
Check for debris or dust: Make sure that the cassette deck is clean and free of debris or dust, as this can cause the cassette to get stuck and the door not to open.
If none of these steps resolve the issue, I would recommend contacting a professional technician or Sony's customer support for further assistance.
The tiny light bulbs are indeed soldered to the front circuit board and a pain to replace. The bulbs can be had at Radio Shack, part # 7219 I did the ones in my Delco/Bose Gold radio in my Corvette, took all afternoon.
we do not have an escort but we are having the same prblem with our expedition...it is the break sensor switch near the petal and only about $13 dollars to repace. Easy plug,unplug instal
