Car Audio & Video Logo
Ronald Koenigs Posted on Aug 14, 2014
Delco radio diagram
I am inside my theft deterrent stereo/CD player looking to disconnect, cut the theft deterrent wires.
1 Related Answer
ted hanson
  • 41 Answers
  • Posted on Aug 14, 2014
SOURCE: How do I find the Wire diagram for Delco Stereos?
If your nice to the dealer concerned they might help you with a diagram.eg what ever make car it came out in.just a suggestion.
Need stereo color wiring diagram for 1995 Chevy Astro Van. Old radio stolen.
Easiest to replace would be the factory Delco AM/FM CD...plug in to existing terminals. If wires cut, you should include the plug in terminals with the replacement radio...Local Pic-A-Part is my go to salvage yard radio $25-$75...Walmart also sells radio wire install kits...$14.95? Hope this helps.
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
2000 delco Toyota radio schematic
Anonymous,
Go to
http://www.the12volt.com/
Look at the top under "Vehicle Wiring" and search for your car.
Press the tab that says "Car Stereo" and Presto, lots of good information. I hope this helps, Ray
2007 Toyota Camry When I put disk in the CD player after about 30 seconds of it flashing saying reading disk it then shows an ERROR 1!?? Any help??? Thks
It can be dirty or faulty disk,but if that's not the case the problem relates to cd player lens.Its not reading the disk.The inside lens which reads and detects the cd is either got dirty or its faulty and unit has to be replaced.-------So whether is dirty lens or faulty that can be confirmed once the unit is inspected.Try running lens cleaning cd in your cd player unit and see if that is helping.========For more help i suggest refer the help links mentioned below:------
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
My 2004 Chevy Malibu Maxx LS Multi CD/Stereo player won't play CD
For Radio related problem,the help links are below.Click the link below to go through its procedure:-----Car radio works but CD player not working?http://technoanswers.blogspot.in/2012/02/car-radio-works-but-cd-player-not.html-----------How to reset Radio code after car battery is died?
------------- Can car radio code block Passkey anti theft system ?
How to wire new car Radio?
Radio Stereo Wiring Diagram?
How to remove radio on Car models?
Where is Radio Fuse located?
----------- After Market Stereo wiring?
No power to radio Scion Xb?
Radio wiring diagram for Car?
How to remove cd player from dash?
This will help.
Thanks.
2answers
I have an Eclipse dvd/cd/avinavi UCNV884RE system in my car, I disconnect the battery and now need to re programed the system to have it working again. I don't have the required software. Is there
For radio related problem,check the radio help links .Click the link be;low to go through its procedure:-----How to reset Radio code after car battery is died?
-----------After Market Stereo wiring?
This will help.
Thanks.
1helpful
Changed Radio and now car won't start
What stereo did you use as a replacement? If you used a aftermarket (kenwood, sony, etc) cd player, you need to use the proper adapter harness. These cars have a build in theft deterrent system that involves the stereo. So, when you replace the stereo, a component of your anti theft system is missing. The use of the harness gets around this feature somehow, and allows you to use aftermarket CD players. Also, ensure that no wires are getting pinched behind the stereo, and that all your connections are soldered and shrink wrapped to avoid any future problems. I have provided a link for the correct adapter harness to your vehicle.
http://www.amazon.com/Stereo-Harness-Oldsmobile-wiring-installation/dp/B000KL2PEI
2answers
Delco stereo unlock code
you need to contact dealer and provide your VIN# to get radio code. It's theft deterrent radio and dealer is only source for codes.
2answers
I just installed an after market stereo in my impala.Now the starter doesn't engage. Is their a wire on the wire harness that affects this?
In the wiring diagrams there is a COMPUTER DATA LINES SYSTEM wire. From what I have read the radio won't cause the car not to start. Did you make sure you didn't drain the battery? Is the Theft Deterrent light on? If it is you're going to need a scanner to get the codes. This is what the Theft Deterrent system does with the radio.
I think if the Theft Deterrent light is on you will have to start there if not just diag a no crank condition.
Top Ac Delco Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an Ac Delco Car Audio and Video Expert? Answer questions, earn points and help others
