Amazon Kindle Fire HD Logo
A
Anonymous Posted on Aug 14, 2014
Can't turn on my kindle fire hd
Won't turn on
Deanna Nassar
Level 2:
New Friend:
  • Expert 167 Answers
  • Posted on Aug 16, 2014
Deanna Nassar
Expert
Level 2:
New Friend:
Answers
167
Questions
Helped
31937
Points
271
Is it fully charged? If you've had it several years it may need a new battery. contact the place you bought it or amazon.com help desk home.
Kindle fire
James, You have to make sure the Kindle is charged, try holding the button longer, maybe even up to a minute, hopefully that will do it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." You can also do a search on google for this issue, seems there is a lot of info. on this problem.
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
12 major Kindle Fire problems and how to fix them
My kindle won turn on Is it the battery Kindle Fire HD
HDX will not boot
2answers
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
Kindle Fire Won Charge Fix
Reset Kindle Fire When it Won Turn on or Charge
2answers
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Amazon Kindle Won Charge Quick Fixes
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
2answers
Text to talk active. need to turn it off, but tapping on top bar has no effect. Unable to get to accessibility. help
Amazon.com: Customer Discussions: Kindle Touch- text to speech not ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 14, 2012 - Has anyone had a problem with the text to speech option not working? It had been ... Press "Menu" button again 6. Touch .... Is it possible to enable text-to-speech in kindle fire? I see the .... Introducing the All-New Fire HD: Powerful Tablets Designed for Entertainment, 0, Sep 18, 2015 ... Most active community forums ... kindle fire hd 7" , touch screen problem
May 16, 2013
Kindle Fire HD text to speech
Apr 10, 2013
Does Kindle Fire HD have text to ...
Mar 19, 2013
Kindle Fire Keyboard Not Working
Sep 22, 2012
More results from www.amazon.com
Turn Off Kindle Fire Accessibility - Love My Fire
1helpful
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
2helpful
4answers
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
