I have sony cyber shot. when i connect usb cord to download pictures to my computer, the computer doesn't recognize it. i have tried another cable, i have tried another computer. when i went on line to get help i found everyone was complaining about this and hadn't found any help either. i tried my old camera and it worked perfectly. i am so sorry i ever bought this thing. can u help?
Here is one possible solution. Some devices require that you use the USB cable that came with the device. Other USB cords won't work. This happened on a Nexus tablet I bought recently. When I tried to charge it with another USB cord, nothing happened. I had to use the exact USB cord that came with the tablet, even though both cords looked identical.
SOURCE: can not download pictures
Your OS may have updated and not provided the driver for the camera. Try any or all of these steps that apply to your situation.
Here are the steps to take.
1. Establish whether or not you have
a connection between your camera/computer by going to your start
button, control panel, system, hardware
tab and device manager. The camera must be powered on and in playback
mode (should automatically go to playback mode when connected, camera's
screen should go black if there is a connection). Make sure you have a
fully or nearly fully charged battery in your camera.
2. Once in
device manager, look under Imaging Devices. If your camera is properly
connected it should show up as Canon Powershot SD800. If it shows a
yellow exclamation point, there is a driver issue, and even if it
doesn't show a yellow exclamation point, you may want to update your
driver anyway by right clicking and having the system search
automatically for driver updates. If download of driver begins,
great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4.
If you have any other imaging software running, exit or close the
program in your system tray (down by your clock in the right hand
corner of your computer's desktop.
5. Try again to connect.
6.
If you are on a desktop, try a rear usb port vs. a front port. You can
also try a different port on a laptop. After each change, try
restarting camera to establish connection.
7. Go to start/My
Computer and look for the icon for your camera...you will be able to
download images even without Canon software loaded onto computer so
this is not a software issue if you have no hardware connection. If you
see the icon, right click on it and choose Get or Import pictures. From
there the default Microsoft scanner and camera wizard should launch and
you will be able to import your images.
8. If still no
connection, try going to Start/Run and type in services.msc here you
are looking for 4 services to be running. Check under status of each
service and make sure it reads that each of these services are started.
Once all of these
services are started on your computer, restart camera once again. If
any of the last three services are not on your computer or are not
started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
SOURCE: pc cant recognize the camera on the USB port
What is the Pc doing that shows you it is not recognizing the camera?
Have you looked in My computer at your drives to see if it is showing there? For some reason mine sometimes shows up my F drive instead of my camera drive. Then you can just click on the drive and open the folder for the photos.
SOURCE: deleting more than one picture at a time
Turn on your camera and go to menu select set up. Then select memory stick it is under the highlighted camera, Then click on format. Go to ok then click ok. Then your camera will read all data in memory will be erased. Then click OK. Now your on your way to a clean memory stick.
SOURCE: Sony Cyber-Shot DSC-P32 won't connect to computer
I think you have a wrong setting, go into the menu and go through it and it says USB connect or something to do with PAL/NTSB i don't have one in my hand.
SOURCE: how to get pictures off sony cyber shot onto computer using usb
When using Windows Operating System on the Computer, follow the steps given below:
Connect the Camera to the Computer using the supplied USB cable. The Computer will recognize the Camera as a removable drive and list in the Windows Explorer. Press the Windows logo on the keyboard along with the "E" key to open the windows explorer. If the Sony Camera is listed in the explorer as a removable drive then double click on it to open and navigate through the files and folders. Open the "DCIM" for images and "MP_Root" for videos. Once the images and videos are visible, right click on the desired file then select copy. Next, paste the selected file on the hard drive of the Computer.
If you want to select all the files at once then press "CTRL+A", to copy, "CTRL+C" and to paste, "CRTL+V".
