SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
SOURCE: HOBART A-200 MIXER- FIRST GEAR NOT WORKING
Hi, your mixer was manufactured in 1947. Hobart does not make public their service manuals. It sounds like the diving key is not engaging first gear with the spinning shaft. This is the ticking sound you hear/feel. This could be because of a broken spring in the mechanism that moves this key in and out, or the key itself has become so worn that it will no longer engage the first gear. The unit needs to be opened up to remove all old grease and oil, including the planetary. The condition of the grease in your description of the planetary, is a good indicator of the condition of the grease in the trans. Your unit probably needs an overhaul due to it's advanced age and grease state. Unplug the unit. You can gently remove the two circular metal dust covers underneath the top cover. With a good flashlight you can view the overall quality of the grease and the level of it. In an ideal world the grease should fill the entire cavity and no oil should be visible. Replacement grease should be Shell Darina EP-2 or Chevron ALC EP-2. You'll need 4-14 OZ. tubes of either type to do the job. The Spec. # for your unit is 3943 Look for drawing # PL-985 Once the cover is off the trans., it's relatively easy to get to the diving key once you remove first gear (the large round gear on top). Remove what you need in sequence, and replace in sequence. If you have a digital camera, take lots of dissasembly pics. When you are done, test in all gears by turning the motor cooling fins with your fingers in the normal direction of the motor rotation. Do not plug the unit back in until you've tested all speeds manually. Good luck! ricardok45
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant. I think the difference is mostly in terms of the no volt interlock switch. This means the KA style N50 bowl won't work with the CE models - too low.
SOURCE: Hobart A200 mixer 1st speed doesn't work 2nd
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
http://www.food-equipment.com/parts_Hobart_mixers.htm
It could be the gear HM2-748
