The problem started all of a sudden. I have pressed the shutter 1/2 way but it doesn't help. Looking on the touch screen everything seems in order but the final picture is out of focus (kind of soft). I really like the camera, have had it for several years with no complaints, and would hope it can be "saved". Thanks for your help.
In many cases, especially when the light is low the camera WILL get confused and it will not be able to focus in low light. In most cases what you pay for is how well it will focus in dim light. This camera does get confused easily. In many cases I have moved the camera so it sees something near what I want to photograph and push half way and the move the camera back and take the photo.
SOURCE: LCD blank & No picture taken
This appears to be a well known CCD problem, which Nikon acknowledges only for the COOLPIX 3100, 5700 and SQ models. Nikon denies the CCD problems on the 5400 are related, even though a Google search for this problem returns numerous results which claim the same defective Sony CCD sensor was used in the 5400 as was used in the 3100, 5700, and SQ models. See this reference: http://www.stevesforums.com/forums/view_topic.php?id=65777&forum_id=21
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
SOURCE: nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
SOURCE: problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
SOURCE: faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
