Kindle won't charge any more. I have been getting a ? over the battery read out for the last couple of months, but after plugging it in to the charger overnite it seems to operate fine until today. After placing on charger no green or even red charging light will come on.
Log onto amazon.com next to search bar is Your Account. Move pointer to bring up list. Click your account from list. On next page, right side is help desk home. click and fill in info on your problem. They can give you info on what type of battery and how to replace; they will answer back by emial or phone. Your choice.
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: Kindle locked up and now can't get it to turn on.
I have the same problem. The screen saver is partially frozen on the screen on the upper right corner and then blank down the rest of the right side. The rest of the screen is readable and I'm able navigate (turn pages, select different books, etc).
Did you figure anything out? Help!
SOURCE: My kindle will not start up even though it has
Yes:
SOURCE: kindle fire has red battery showing. I have charged it but it wont work
It may be the power cord but it is possible that your Kindle Fire's battery has died. If you noticed
the battery life diminishing before it started flashing a red battery symbol this may
be the case. Here is a site that has replacement batteries for the
Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
