Toshiba 62HM95 62" DLP HDTV Logo
A
Anonymous Posted on Aug 16, 2014
Why won't screen come on
Green light noise then red flashing light
AAA TV Service
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Aug 16, 2014
AAA TV Service
Expert
Level 2:
Sergeant:
Answers
272
Questions
0
Helped
64855
Points
688
Is it a buzzing sound?
Check the lamp, the glass of the lamp may be shattered?
www.aaatvservice.com
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
2answers
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
2answers
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
1helpful
2answers
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
