Kenmore 80's series top loader fills, agitates on wash , will not release water on spin cycle. I can manually move it to rinse, but again , it stops working once it encounters the spin cycle. There is a click sound at the end of the wash and rinse cycle, then everything is silent- no noise- no spinning , and it just remains that way until I manually move it -only works on wash and rinse cycles!
Kenmore 80's Series Top Loader
MOD 110. 23812100
SER CM 2022848
Type 111
Hi, I decided to replace the lid switch first (I just didn't feel like dealing with a washer full of clothes and water). Upon inspection, the switch was clearly broken or popped open,if you will. That solved the problem! (I read other peoples' commentaries with similar problems and that's what drew me to replacing the lid switch.) However, if this had not worked, checking the pump for clogs would've been my second move! So, I do thank you for that advice. Thanks, again!
works completely fine in permanent press mode. Will work normally if manually moved dial other wise will continue to wash only
