Dyson DC17 Animal Upright Vacuum Refurbished Logo
A
Anonymous Posted on Aug 16, 2014
Why does my Dyson DC17 pushes ******* carpet?
It has become almost impossible to push my DC17 on carpet. I have thoroughly cleaned the vacuum, replaced the brushroller, belt and washed the glide plate on the bottom. What else could cause it to not glide easy like it used to?
Zululander
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 16 Answers
  • Posted on Aug 17, 2014
Zululander
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
16
Questions
Helped
3359
Points
25
Check the glide pate is fiited flash.
2 Related Answers
Alex
  • 97 Answers
  • Posted on Jul 29, 2009
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
Anonymous
  • 167 Answers
  • Posted on Apr 15, 2010
SOURCE: Dyson Animal Vac has become hard to push
Hi there, check that your brush bar is going round if you are having this problem on carpet. When the machine is stood upright, ensure the brush control dial is in the centre position when upright and then moves forward when you release the head.
If this does not solve the problem call us on 1866MYDYSON as we may be able to run through some more checks to help you.
Kind regards
Darran
Dyson Customer Liaison
Cannot push my DC17 animal forward on plush carpet. front digs in.
Make sure brush is spinning properly and that all wheels on base plate are there and spin freely. Make sure bottom of baseplate is clean. If these are all ok you may need a model that offers height adjustment for your style of carpet.
Why does my Dyson DC17 now push really ******* carpet?
Have you correctly replaced the glider that covers the brush? You need to make sure that the clips are fully seated .
Extremely difficult pushing vacuum over new carpet
Hi Julie,
I'm sorry to hear you're having difficulty using your DC17 on this particular carpet type. I'd encourage you to contact the carpeting manufacturer for advice, as they should be able to recommend the best way of cleaning it.
If you'd like any further assistance with your machine, please email us on [email protected], or give our customer Helpline a call on 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
My DC 17 will not clean carpets....when I push the button to engage the brush to clean carpets it does not work...the vacuum is in the proper position for carpet cleaning
I'm sorry to hear you're having difficulties with your DC17. It's a good idea to check for anything which might be obstructing the brushbar or cleaner head - the easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=956&product=DC17-ANIMAL
This should allow you to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in contact as soon as possible.
Kind regards,
Jack
Very hard to push. It started gradually but now its nearly impossible to vacuum the carpet. Is this an easy fix?
I'm sorry to hear you're having difficulties with your DC17. If the cleaner seems more difficult than usual to push, it's a good idea to check the soleplate for damage, and to remove any threads, hair and other obstructions from the brushbar. The easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=961&product=DC17-ANIMAL
You may also want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brushbar. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further questions or concerns, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in contact as soon as possible.
Kind regards,
Jack
Kind regards
Darran
2answers
When pushing foreward the vacuum is hard to push and if pushed on to hard it will turn over on itself.
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.
7helpful
3answers
My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
17helpful
4answers
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
