Why is not the daewoo dwf 200 le not accepting the water from the pipe outlet and how to fix this problem?
I guess you either have blockage in the outlet pipe or the drainage pump is out of order , so you can 1- pull out the hose from the pump and blow it for any remedy 2- check voltage on pump if available while draining the water from the machine 3- open the pump and clean it if it didn't work replace it
I assume you mean the unit is not filling? If so try setting it to fill cold wash only, then hot wash only. Whichever one does no fill is the bad solonoid, replace it.
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure.
This sensor is used to know water level in the tube. It is probable
that your model reports the same codes.
It does not necessary means
a broken sensor you must check the electrical connectors and cables as
well as all the mechanic and pneumatic elements like the hose connected
to the sensor.
It is often clogs with soap and other particles.
Good Luck!
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
